Fuel Line size
geo7
I have a Mercruiser 120 hp 1983. I just installed a new gas tank. The fittings on the tank are 1/4" pipe outlet. The fitting on the fuel pump are 3/8" pipe with a barb fitting of 3/8" for hose. I need to buy an anti siphon fitting for the tank with a 1/4" pipe with a 3/8" hose barb. Will the constriction at the tank cause a problem. I would like to run a 3/8" line from the tank to the fuel tank and yes I will be installing a water separator and filter.
stonyloam
Re: Fuel Line size
Considering that your carb jets are about 1.45 mm I don't see a problem;).
geo7
Re: Fuel Line size
Thanks, I will go with the 3/8 line. Just was concerned it started out 1/4.
