Re: 1994 Johnson 90hp Rebuild .030 Over Questions
Cool that will work for this motor. I do have carb kits, new water pump and stats as well.
I am also building another motor and one side the cylinders were ok so they were just honed but the other side had to be bored out. One cylinder is .030 over and the other is .064 over. I thought it was odd but the machinist said they do it all the time. How about that one as far as jetting? I would guess they would be ok as well cause you wouldn't want to run the stock cylinders to rich?
