We were heading out on the lake yesterday cruising at about 5200rpm and the alarm went off. I shut the motor off, took the cowl off and the motor was only warm. Fired it back up, the stream was cool. Everything on the motor was warm, but not hot. Waited a couple of minutes, fired it up took off and it did the same thing. Everything was as previously mentioned. On my remote is says that a steady beep without loss of power is a fuel restriction, but in my manual it says the only alarm is an overheat. Now I am confused and don't know where to start.
