NS5B service manual
Porta-mo
I have an 1989 NS5B motor and put a new impeller and waterpump kit in, now I have noticed a leak where the shift linkage goes into the lower unit.....need to replace O-rings, or bushings, need help in finding a kit to do so, also have trouble shifting it after putting it back together. Any suggestions.....anyone have a used service manual they want to sell.....I see they are pretty pricey.
Sea Rider
Re: NS5B service manual
Do you mean water, oil leak ? the shift linkage is not visible, only through big round grommet, as runs through leg interior, the only visible part protruding is the cam rod extreme, has a rubber grommet and plays against reverse lock arm.
Happy Boating
pvanv
369873210M LOWER UNIT GASKET SET $21.23
Service manual Part# 003-21035-1 $44.17
