Facts: 50 HP Suzuki 4-stroke outboard; 18 gal fuel tank in the bow of a 16 ft Glasspar; Approx 18 feet of 5/16th fuel line.
The primer bulb goes flat after a few minutes of running the engine. I took the gas cap off to ensure air is getting into the tank, but the bulb still goes flat. The fuel pump suction must be more than the fuel line can deliver, or the smaller bulb can deliver, or both. I figure it's like trying to suck coke thru a very long soda straw with a mushy embolism (bulb) in the middle. The bulb is going to collapse.
Question 1: Will a 3/8th line and bulb make a difference?
Question 2: Do they make a larger, more robust bulb than the low-end Moeller that they carry at West Marine?
Question 3: Is there an alternate priming mechanism (i.e., something other than a squishy bulb)?
