economate2
- Jul 29, 2011
- 36
Model # is 32H0D
I fixed it up this summer and had it running flawlessly for a while. Then started having problems again. Here is the symptom:
Have to crank about 5-6 times to get it started. Starts only at full choke (air valve closed). As soon as it fires, I have to open it to half-choke. Usually right after that, I would close the choke (air valve fully opened) and it would run great. Lately after running it for 10 minutes or so, it would start dieing on me, and I'd have to choke it and unchoke it quickly to get it going again. And this would happen more and more frequently. Lower RPM's work without having to do that. Now, it does not run with the choke off at all! Choke has to be half-way in for it to run. As soon as I open it fully, it dies, and the same thing when I close it fully.
What's the problem?
What's the problem?
