Aluminum must be bare and all corrosion removed. (including seams...) use alumiprep, then alodine, dry, self etching zinc chromate, let cure for several days, then spray good high quality poly paint with hardner.
If ya jus want a quickie cheap job: Cheap automotive enamel and use 3M pad to scuff up and paint two coats.
