All of a sudden
dedo
I enjoyed a nice fishing trip without any motor hickup or concern. When I arrived back to the house I wanted to run fresh water through the engine, it would not turn over. The battery became too weak. I pulled the battery and had it tested(good) and charged. It started right away.
1990 48hp Evinrude SPL. Could it be that a 4 month old battery needed fluid added and a recharge?
Or, is there a motor component that is not charging the battery?
109jb
Re: All of a sudden
It could be one or both, or neither. We need more info.
How many starts and stops during the trip, do you have a trolling motor on the same battery, fish finder, radio or anything else? What size is the battery? IS it a marine deep-cycle battery, marine-starting battery, automotive battery, etc?
JBooth
Re: All of a sudden
If you run your boat a lot it probably just needed fluid. If not it is a 21 year old motor, so the alternator could have a problem. Hope this helped.
Fireman431
Re: All of a sudden
A 4 month old battery should not need water added after a simple recharge or two. In fact, batteries that are on constant trickle charge from shore power (like mine) only require checking levels every 3-4 months or so. I add a bit of distilled water approximately every 8 months...so yours should not need it, unless it's leaking.
Check the charging system on your engine first. Also, if you motor just a short distance to fish, the engine doesn't have sufficient time to recharge your battery on the return trip (fishfinder and radio all day with a 10 minute ride back to the dock). Check your charging system first.
spdracr39
Re: All of a sudden
If your charging system is overcharging it could boil the water out on long runs. Have it checked for sure.
