SSTKO81
- Jun 1, 2009
- 341
Hey guys!
My '81 Alpha is trading water and oil everywhere. I've found oil and sand all over down around the impeller and signs of water mixed up in the oil. My very first thought is the most simple. Maybe the little o-ring between the top and bottom went bad... still possible
But when I opened the two halves up, I found a rubber ring with a spring on it and the reamains of a chewed up water tube seal. Whats this thing w/ the spring?
I bought an upper seal kit from iboats.com, but Im not totally sure where all these seals go. Any help? A close up detailed diagram would be great.
I should probably also add that I noticed a little oil coming out around the inlets for the water impeller.... Related issue?
