malo68
- Aug 22, 2011
- 10
Hello everyone! My name is George and I?m new to the forum. Over the summer, I was looking for a family boat and ended up finding this running 2000 Bayliner Capri 1850 with trailer for $2000. The previous owner did not take very good care of the boat and it sat outside for quite a while without a cover. Needless to say, there was mold and mildew all over the boat but that was the least of my problems, I?ve found. Before I bought the boat, the owner told me that he had to patch a spot in the deck. He did this by putting a rough cut piece of plywood over the rotted area. When I got it home I stripped the rug to see the extent of the damage. I found what you see in pic 1. At that point, I began to research many articles and threads here on the forum and also on the internet. I found a thread about a guy who had a similar boat with water penetration problem under the deck behind the wheel where the driver?s feet would be. I decided to cut some random squares in deck there and felt damp foam. I then decided to cut a square towards the back where I saw a buckle in the fiberglass to check for bad areas. When I cut the square in the port side rear, I saw foam, then a void in the foam. I stuck my finger in and I was touching water! I opened up the hole, took the section out and my jaw dropped. Water was trapped between the stringer and cross section. The foam was saturated. I then saw a 1? hole in the stringer that had saturated foam in it. The hole was not sealed with fiberglass and water penetrated into the stringer. I dug out the foam from inside the stringer and found that most of it was dry except for the very bottom. After digging sucking out the water and digging out the foam, I couldn?t help but notice how lousy the factory fiberglass job looked on the underside (see pic) with loose strands of fiberglass everywhere. Water obviously penetrated the cracks of the very thin layer of resin on the topside of the ac plywood deck. The underside of the plywood is untreated?bad idea. Anyway, looks like a have quite a project on my hands. The next problem I will encounter is dealing with how to replace the floor without splitting the boat in half because the walkthrough areas on the side of the helm are built into the top half of the mold. This should be fun. I?m sure I will have a lot of questions in the future about this project. I was very inspired by bear_69Cuda?s documented project. I hope to document with pictures as I go along as well. I will be eternally grateful to be able to get some helpful insight from the many experts and enthusiasts I?ve read about here?Take care all! George
