Re: yamaha 100hp 4 stroke
you need to post the year and model. if it is fuel injection, you need to clean the VST chamber, the fuel pump screen, get injectors sent off and cleaned and flow tested, new filters (all). new spark plugs, check TPS, check isc valve, clean fuel rail..have motor hooked up to a computer and checked for fault codes.
