I just bought my first outboard from guy on craigslist. It's a 3.9hp 1967 merc. It started right up at his house and then I took it out on my boat with no issues. Then I took apart the carb to clean it, also replaced both fuel lines because they were cracked and leaking when I took the cowl off.
Now this is the first outboard I've owned. I've used several others before and never had a problem. THis is what happened:
I was out today fishing and I rode the motor at low-medium speed for about 10 minutes through some shallow areas. Then I shut it off for about 3 hours while I anchored and fished. Then I started it back up and started moving along slowly just checking out the lake I was on. All of a sudden the motor dies and I notice a lot of smoke coming out of the top. I assumed it overheated so I let it sit for about 30 minutes. I started it back up and it ran just great for another 20 mins or so when I made it back to the launch.
I'm just wondering if this is indeed an overheat and if it could have just been caused by running in shallow water and kicking up a lot of silt. I did run it again in shallow water on the way back and had no issues... Also, I replaced the fuel lines with tygon because I could not find original lines anywhere and I noticed they are a little larger diameter than the originals. Could this cause an overheat?
Is it a real pain to pull the lower unit apart and check the impeller if I've never done it before? I did take the carb out and completely disassemble/reassemble it without ever doing it before.
Are there any other maintenance things I can do to prevent this or other issues with this old motor? I know these things can last forever if you take good care of them.
Thanks in advance!
Thanks in advance!
