I'm in the process of rewiring a small bass boat. Is there any reason NOT to break the ground wire with the switch, as opposed to breaking the positive wire? In my case, it would make the hot wire much shorter, and therefore reduce the amount of hot wire subject to wear, shorting out, etc. Some of mine would not even pass through any hull panels. I realize that I'd still have to fuse the hot side.
John
John
