1989 Evinrude 110 VRO
Skulldrag
My motor starts and runs fine for the first 30 minutes or untill I stop. After first stop my motor will not get boat back on top unless I pump the ball. As long as I'm pumping the ball motor runs great,stop pumping and the motor wants to bog down. What's up with that?
oldcatamount
Re: 1989 Evinrude 110 VRO
Sounds like the motor is loosing it's fuel prime either from a crack in the fuel line or loose clamp connection. Could be that the VRO pump is bad but I'd check the fuel lines first. The pump will be pricey.
