Jason89sunbird
- Sep 5, 2011
- 59
Bought a 500 dollar special, cracked block and interior shot.. redid interior, not fancy but wont hurt to sit on lol. Had a vortec out of 1997 blazer so I installed it with cast iron vortec 4bbl manifold, regrind cam duration 210ex 210in lift 440ex 440in lsa 112, holly carb, 90 blazer dist, 97 blazer coil and 67 camaro water pump(11.99 at oreilly's. original omc cobra harmonic balancer, pulleys, brackets, starter, alt and p/s pump. The boat already had merc manifolds with 3"risers(why 3" risers???, should have been 4") Purrs like a kitten, shift into gear out of water with a slight grind both foward and reverse. So I took it out on the Willamette river in Salem OR for the first time after work. it shifted into gear again with a grind and a stumble (esa working?). once in gear it ran like a champ even with the carb over jetted for a v8 but it wouldn't shift out of forward to neutral at all, the rpm's were about 1500. Were the rpms to high or do I have a dreaded shift cable alignment problem?
Thanks in advance, Jason
