reverse lock
Price
Is there any web site I can get a exploded view of a reverse lock? I think I am having trouble with mine. The tilt will not travel all the way down without some help and I have bleed the system several times? (78 mercury 165hp)
Re: reverse lock
Those are Not the Symptons of a faulty Reverse-Lock,........ That would be the Drive Jumping Up in reverse.............<br />Or something Exploding from Excessive Pressure when you Try to trim Up............<br />I Think if you unplug the 2 wires,.. It'll ceace to function.........<br /><br />Your Issue sounds like Dry Pivot Pins......Something is Siezed,.. Or about to be.........<br />The Trim Pump,... Pumps Up,+ Out..... Gravity,+ drive Thrust Push it Down.............<br /><br />The Pump makes High Pressure on the Up,+ Out side,.. But Considerabley Less Pressure on the In,+ Down side........
Laddies
Banned
Re: reverse lock
You probable have a bad cyl. remove the rear connection bolt and only one will work, if thats the case rebuild them both--Bob
Price
Re: reverse lock
I found the problem,it is a bad cylinder. Now I have to figure out how it get it apart. I have got most of it apart but, someone told me I have to get the end pieces out by beating it against a block of wood? Is this true? Which end do I hit? Thanks for the help so far!!
Laddies
Banned
Re: reverse lock
Price, put the end cap back on the cyl. so you don't hurt the threads as sometimes you really have to slam the cyl. down hard to get the tube and the other peice out of the cyl.
Re: reverse lock
What are you guys Beating On ???
Price
Re: reverse lock
The cylinder. I tried slamming it down (several times) with no progress. Will heat help remove it?
Re: reverse lock
Hook up the Out Line,+ Let the Oil push it out...........<br /><br />Heat will Destroy it.....
FreeBeeTony
Re: reverse lock
I bought a rebuild kit..........to get the plunger(?) out, I actually cut the old housing! NOTE: this kit is for a pre-Alpha.
