Re: 40HP Tilt motor replacement
way too early for that motor to go out. you sure its broken?
remove unit from engine. there is one long cross bolt on bottom and a mounting pin at top. brace engine securely to avoid loss of fingers, hands, or head. once removed put trim system in bench vice and carefully remove socket bolts holding oval shaped base onto reservoir. do not allow debris to fall into fluid. do not remove old motor until new one is handy. once bolts are out lift motor straight up. there is a loose fitting that goes bettwen motor shaft and pump shaft. be careful to properly engage with new motor. install new motor and screws. bolts should be secure but not overtightened. use bolts with locking patch or use regular bolts with locktight to prevent loosening with vibration.
