I bought a boat Friday. It has a 1975 Johnson 70hp engine on it. It cranks right up and idles well, but I haven't had it on the water yet. It has a fuel leak where the cover is for the carbs. I took the cover off and sure enough half a gasket. I have no idea what this gasket is called but it is half missing. I then took the spark plugs out. All three were covered in black gunk about half way across and the other half looked pretty clean. They also appeared to be damp or sort of wet. The spark plugs look to be pretty new. I took a look at the top of the piston heads and they too had black/brownish gunk on top of them. It was only on about half of cylinder 3, I could see a clear line of where gunk was and then a nice clean piston head. I really wasn't able to get a good look across cylinder 1 and 2, but what I saw was blackish/brownish gunk built up on it. Any ideas or suggestions?
