I have a 2004 Mercruiser 5.0L MPI. Engine has been running great. Got a new prop and have been happy with it. I put in on the water this weekend and could tell it was taking on water, but nothing too bad that the bilge could not handle. When I got out on the water WOT was 2000 RPMs less that is was last weekend, therefore it would not plane and max MPH was maybe 5-10. Prior to this weekend I did change the fuel filter and the sterndrive gear lube. The motor runs great just 2000 RPM less. I also looked on the prop and a couple of the blades looks like someone backed into it. Has anyone had this problem or have any suggestions? Thank you!
