back flushing engine
abaker
Is it possible, to back flush a 5.7 Volvo penta thru the exhaust, i have flushed all the lines but i still can't find one piece of the raw water pump impellar, and it is too big of a piece to go thru on its own. Any suggestions will be appreciated.
Re: back flushing engine
Ayuh,... Other than on the bench, with a bent up coat hanger,..??
I can't see it happenin'...
Pull the hose fittings, 'n risers maybe,..??
Ciera2450
remove the thermostat housing also and check there...
