I have a problem since last year with my boat going into forward.
If i move the lever into forward at a normal rate it will rev high before going into gear and because of the high rpm it goes in with a clunk.
If I move the lever into forward position and wait maybe 30 seconds it will go into gear or if not i will move it a bit more forward and raise the revs by 100-200 rpm and then it will go into gear.
I think this is the cone clutch problem????
How can I check this
Thanks Colm
Thanks Colm
