Motor stopped peeing altogether. I tried dropping the lower unit but that is where I got stuck. I removed the 4 bolts and the lower unit came down about 1 inch, enough to see the water pump housing, the drive shaft and then towards the front, a wire (about the size of a coat hanger, I'm assuming that is what changes the gears from forward to reverse). This wire is what I could not figure out how to remove or disengage. If anybody has any suggestions please let me know. Also, where is the best place to get a new impeller as well as new water intake screens (the plastic things that are on the outside of the motor where the water goes in)? Lastly, when I put the new impeller on, do I need to to make sure it turns clockwise or counter clockwise? Thanks for any insight / suggestions you might have. Any pictures or diagrams would be helpful as well.
