Re: 1997 mercruiser 7.4 water pump
Hello all, new meat here with a problem. I need a new water pump on my 1997 Sea Ray w/mercruiser 7.4. Totally locked up.
Problem is the cost $$$.
However, there is one for sale on craigslist, brand new for $260, compared to $579 to $750, and the part # is 46-807151A8, same as mine. But the ad says it goes with a serpentine belt. And I do not have a serpentine belt on my 7.4.
My question is, would that pump still go on my engine and line up with the individual belts I'm running with now?
Any and all info would be greatly appreciated! TJ
Howdy,
Welcome Aboard!
You most likely have the same pump that I have on mine.
If you allow the pump to either lose oil through a leak or allow the fuel pump to leak internally (and dilute the oil with gasoline) It will eventually destroy the bearings and self destruct( seize etc).
I actually was able to replace my fuel pump prior to this happening (replace the oil [Mercruiser gear lubricant]) and save the bearings.
You didn't indicate whether you have a carbureted or MPI engine, but if you DON'T have a mechanical fuel pump on the raw water pump drive, you may be able use the cheaper pump....BUT the pulley may not line up after you remove the serp pulley and press the v-belt pulley on (even if you can)
Examples are at the link below.
http://www.sterndrives.com/precisionparts/328.html
An example of how to rebuild one is below:
http://www.sterndrives.com/rebuild_bravo_raw_waterpump.html
If you have a mechanical fuel pump on your sea water pump, you will have to either rebuild your current pump drive, (and replace the fuel pump) or go to a (USCG compliant) electric fuel pump.
If you want to rebuild your pump support/drive, it will entail pressing the pulley and bearings off the shaft and getting new ones etc.
I don't know if the bearings and/or drive shaft are even available though.
I believe Mercury has electric fuel pump conversion "kits" etc.....
Either way it's not going to be cheap!
Sorry about that!
Rick
