pontoon1991
- Sep 3, 2009
- 19
I have a Force 2 cyl 50 hp. Coming in toward dock and the engine decided to die. I don't personally know that much about boat motors. I figured I had fouled a plug driving so slow. In the process of pulling the plugs, I noticed the lower plug had a couple of water droplets on it, and it was very clean, like it had been steam cleaned, so I figured head gasket.
I ordered a head gasket and cleaned the gasket surface meticulously, cleaned screw threads, dipped them in oil before installing. So, what I am saying is I feel I did a very good job on the head gasket. I tried to start the engine and the same thing - couldn't get it to idle. I checked the plug and saw droplets of water on the tip. My question is, is my thinking right, I either have a very bad head surface or a crack in the cylinder. Is there any way other than that for water to get in the cylinder?
When I disassemble it this time, what should I look for besides surface of the head or a crack in the cylinder, and where should I look to inspect this. I went and got the old gasket and inspected it for water erosion but was not able to find any. Any thoughts will be greatly appreciated. It seems like I am having a very bad time right now money-wise.
Thanks for any advice.
