Bonecrusher1
Thread starter- Joined
- Sep 5, 2011
- 2
Hi - new to posting on the forum...I have a 1957 Johnson 3HP - model #JW13. This engine has been in the family for 30+ years...stored in a barn for the last 20 years. After cleaning the cob webs off the engine; I did the following:
1. Removed gas from tank (or should I say varnish)
2. Replaced spark plugs
3. Added lower gear case oil
4. Clean carb (w/carb cleaner - did not use rebuild kit)
The engine ran strong!! (after adjusting the low/high speed idle ajustments).
I ran this engine several times around the lake; about 3 tanks of gas.....this engine would start with just a simple pull....
Now....it is hard to start....and I think missing at both low and high speeds. At high speed, it will run rough, then clear up and run beautiful for a second....return to running rough....
I'm thinking it must be electrical....I'm off to the store to buy a spark tester.....can points/coil cause to run rough then clear up for a second and run great?
The motor ran so good....I know it wants to run again!! Thanks for any help....
