jgresham75
- Aug 19, 2008
- 70
1999 5.0GL (replaced w/5.7 block). I will try to be brief but the question is, will the head gasket eventually seal based on the following:
Had the head rebuilt and planned. Assembled with NEW head gasket with NEW bolts. Did not tighten correctly and had major leak. Bought Another NEW gasket and NEW bolt set again and tighten head according to VP service manual (torque/angle). (It is possible that my block is not flat). HOWEVER, I DID NOT clean the bolts holes between the two NEW gasket replacements (Please don't beat up on me about being careless. I am fully aware of my mistakes and my wallet is paying for them). I then started the engine and it went ok but started to see a little water drip on the outside around where the bolts are. I put the boat in water and got it up to operating temp for about 15 minutes. Most of the water stopped except for one small drip.
IF the water is dripping from the bolts holes, is it possible they may eventually seal with more time?
(please note, it is entirely possible that my block deck is not flat, thus the gaskets leaked once the heads were planned. Therefore, my concern is that I need some major overhaul and will probably replace the block anyway- BUT would like to get some use out of the block before replacement. Therefore, I am asking this question.) Thanks in advance.
