OK - plenty of guys saying to open up hood, disengage shift cable and manually shift lever (have done so, still likes only reverse - even if I get into fwd by rotating shift lever fwd by hnand, it lasts mere seconds and slips back), but some posters say to PULL up on shifting rod to get into FWD Gear, then tighten shifting rod (or make sure shifting rods are tight), and one who advised he just went through this on same engine make/model/year and I need to follow this advise from him:
I have evinrude big twin; it is the same way, Just had the bottom end redone from a boat mech so i doubt anything inside is bad or he would have replaced it - I even took my shift cable off and put it in gear manually and it still poppin out,so i went all over it and found the linkage bolt was loose! i hope this fixes it for you!
OK, here is an exploded view online catalog (FREE, just click to it and see exploded views of this engine , with next page being part numbers for the exploded view item #'s...) Has dozen or so exploded views.. can anyone help me determne WHAT levers, or bolts to tightn, or adjustmnts to get it shifting right? PLEASE - look at explodfed views and then I can see exactly what you mean and refer back to it!
LINK TO EXPLODED VIEWS:
http://www.marineengine.com/parts/v...evinrude-johnson/ITEM_2977/ITEM_297700001.htm
elI cant tel you all how appeciatve I am for any/all help!
Thadius Main
Thadius Main
