specktrout9
- Sep 4, 2011
- 3
I have a 6.2 mpi bravo horizon with bravo 3 outdrive new in '09
Had numerous problems...Was running home after a short run (3800rpm) and the alarm goes off. Pull the throtle back and the engine dies while the alarm still sounding. Tried to re-start engine and cranks slow and starts up...turn back off as alarm still sounding. Check temp gauge and it's running a little hot (185 deg.) Pull engine cover and ck all fluids...all ok...Re-start...cranks right up...notice oil pressure around 10-15 at idle (normally at 20). Notice the water temp goes down...check outdrive for debris (None) and bring boat up to plane...run back to inlet w/ no issues. (oil pressure at 38psi @4000rpm..)
Try and go fishing next day and alarm has intermitent beep (two beeps every min.)
All fluid levels fine...back to dock again...any thoughts???
Bob
Bob
