I have a 1990 40 hp with out pumping the priming bulb i try to start the motor i use the choke and no choke i know it is getting fuel i can smell it and there is spark good spark check that too , top piston is 107 and the lower is 103, and i alos have oil dripping from the prop, it isnt crank case oil that is clean and a think and blue check that too can someone help point me in the right direction if it was a chevy i would know what to do.
ALSO on the control side of the motor there is a cyclinder looking thing with a little orange switch on it what is that and how should the switch be positioned
