base190380
- Sep 3, 2011
- 4
Hi there i have, a bayliner 2052 with 4.3 ltr mercruiser v6 engine- year 2000.
its the carb version with electric fuel pump, and thunderbolt ignition.
i have a problem all this season which i cant get to the bottom of. it will start and idle perfect and run at low speeds perfect, but when under load at 3/4 to full throttle i get popping from the engine like misfire, and sometimes a backfire through the carn / intake. its also down on power and sometimes hesitates when underway at speed.
i have replaced, spark plugs, ht lead, rotor arm, distributor cap, ignition sensor wheel and also ignition sensor inside the distributor. new coil, new fuel filter also fitted. tank was completley pumped out and refilled with good fresh petrol too.
basically if its revved out of gear its fine but just under load i get problems, any ideas?
fuel pump is operating as i can also hear it buzzing.
