I have an aluminum boat with a 1989 suzuki 55 jet. The cranking battery is grounded to the entire boat via the motor, (I'm assuming). There are no ground wires attatched to the hull. I rewired the entire set up. I hooked up the stereo to the trolling motor battery, but it work now. Red wire to trolling battery +. Black to trolling battery -. Yellow not wired. Display light comes on, but thats it. The antenna is mounted to the console which has ground to the cranking battery. Is there something I can do with respect to the antenna to make this work, or do I wire the stereo back to the cranking battery? I don't want to be on the water with a dead battery.
