help my outboard is driving me crazy. it starts and idles not to smoothly but not really ruff as i head out onto the lake i move thorottle towards full thorottle and it planes out and runs for about 15 minutes. came home and rebulit the fuel pump, lines to carb, and replaced the needle and seat and cleaned the fuel filter and bowl. put my test barrel under the jet and ran motor pulled the fuel lines off to check for fuel and its pumping really good turned off motor to reattach fuel lines primed bulb and started it back up it ran for about 10 minutes then just shook back and forth then died tried to start back up no luck unless i pump the primer bulb ran it agian then it died again while i was shakeing my head i touched the spark plugs and noticed that the number 3 plug was hot and number 2 & 1 were luke warm at best so no i am wondering what the heck is going on i am thinking ( or maybe i shouldnt ) that the top 2 plugs arent firing. if anybody has any ideas i can try please send them my way the steel head are in the river and i gotta get out there thanks Dennis
