Re: 1946 Evenrude Sportsman 2-horse
Hey, I just picked up a pretty nice one for $20 at a neighborhood garage sale, most decals except one complete though a little faded. Didja find a source for an impeller yet?
Actualy I did a partial teardown of the lower unit to regrease, so forth. In the 1946 4412 2HP, the impeller is
steel(!) and in my case, in perfect condition. There are some oddities however. The "seal" on the output for the
propeller is of babbit or lead?? Very odd. A company called McMaster-Carr sells all sorts of seals one could try, however I am going to keep it (it is in pretty good condition) and use marine grease in the gear case. Heavily
packed, frequently changed as in once every ten outings or so. As for seals around the impeller, I am awaiting
the original (but 1948, not 1946) repair manual/parts list for it; the lower half is different but I doubt things
changed around the impeller much in terms of design. My motor had NO seals around the impeller, and it MIGHT have a spot for one (again, I propably will have to jimmy up some kind of seal from McMaster-Carr online I think, is the only possibility for a seal). Also again, the manual for the '48 motor might provide insight as to the shape of any seal around the impeller area. As of lower case gaskets, it would seem one can make these using standard old thin gasket material from say, NAPA. Hey, anyone have a lower unit for a '48 with the skeg intact? I might want to buy it, my skeg is half broken off. --Hilary Herman in the redwoods of coastal
northern Calif. PS THIS IS A FRESHWATER-ONLY MOTOR, DON'T EVEN THINK ABOUT SALT WATER!!!
