2008 200 HPDI with jet pump
eric8it
when i got home last night it hooked up the hose to flush out the motor. I noticed that while i had a lof of water draining out the lower end of things i only had a dribble coming out the cooling water pilot hole. Since i am using the garden hose wash out connection i assume its not the water intake or pump. Not knowing the route the garden hose wash out takes could something have got into the line to block water from circulating through the motor? any suggestions would be appreciated. thanks,
99yam40
Re: 2008 200 HPDI with jet pump
I would try blowing out the tell tail with compressed air to start out with to see if it helped or run a piece of heavy mono up it or both
