woodsyfeller
- Aug 15, 2011
- 182
Changed the impeller on my 74 9.9 johnson today noticed that water was entering into gearcase (before I changed impellor). I was wondering if the drive shaft just pulls out ? I wanted to replace the seals under the impellor but wasnt sure how to remove the driveshaft.When I was changing impellor the drive shaft did pull up but I didnt pull it out in fear I would mess something up. I also plan on replacing the seals and the o ring in the prop area since I see oil coming from the prop exhaust area.
