Re: shift shaft removal
I figured it out had to remove the bottom carb to see both bolts on the nuckle that connects the two. Used a 3/8 socket and 6" ext. and ratchet and was able to get at the pin bolt that connects the shift rod to the nuckle with shifter in reverse. Putting back together might be another story.
