Hey guys,
I've been a lurker here for a few months now. I'm a very experienced mechanic on motorcycles, small engines, cars, and have been an aircraft mechanic for 23 years but this engine has me stumped!
Here is the quick background info;
-165 Mercruiser with a cracked bloc under the manifold
-Manifold was also cracked
-Bought 250 GM truck motor with 77 000kms but not run in 3 yrs
-did a swap of all marine stuff
-pulled the head, checked cylinders, valves reassembled new gaskets.
-installed the motor with-out a snag at all
-New battery, turns over great.
-Has good spark in all cylinders
-set up timeing staticly
-rechecked the valve lash
-compression may be a little low because it hasn't run in a while but I oiled the cylinders well to help
Damn thing will not fire up even when I use Ether. It has backfired once or twice but never even tried to start.
It just does not make sense!
Does anyone have any suggestions that I might not have tried!
Patiently waiting for the genius who tells me that one simple trick and make me look like a fool!
