My force 125 needs carbs cleaning. It seems that something is blocking fuel, it can not idle and this happened in 2 days it was getting worse and worse. Now I can start it only on high throtle on idle. When I reduce throttle it dies . I checked spark, works on all 4 cylinders. I checked fuel diaphragm, I will change this also but it looks good. Anyway I was planing a carbs cleaning so please point me some important things for which I should be carefull when disasembling carbs. I am planing to unscrew it from motor and then everything is adventure for me. So if there is some topic where this was before explained please write me . I searched some videos on youtube and there are instructions for carb cleaning but not for force . Is it good to wash carb in a diesel fuel or some other liquid is better? Thank you for help.
p.s. I am also suspecting in water in the fuel but this is less likely, first I would like to clean carbs.
