penguin356
- May 3, 2005
- 8
Quick question...<br /><br />If I take a regular marine/automotive 12V Negative ground tachometer and connect the + side to the + side of the coil and ground it to the block, in essence I have created an external tach.<br /><br />Automotive 3 wire:<br />+ to the Battery <br />- to the block/battery<br />Signal + side of the coil or wrapped around a plug wire<br /><br />Right?
