Mercruiser 4.3L V6
Thunderbolt IV Ignition
Stock cam
Before I quit trying to correct some low WOT issues last night I pulled the distributor cap off and found that I can turn the distributor rotor clockwise and counterclockwise by hand - basically it has some slop in it. I'ts not 90 degrees or anything, but maybe 20 degrees or so? I don't know if it's just the rotor turning or if it's the rotor and shaft turning - but I plan on checking that when I get back home this afternoon. I did not notice any side to side movement of the rotor (no bad bushings) or vertical movement.
Should the rotor be pretty solid in the housing without this "slop"?
Maybe it's not possible to have a loose rotor on the shaft - which would mean bad distributor drive gear... And if that's the case, would I need a special replacement for this gear or would one from an auto parts store work for a same vintage GM 4.3L V6?
Thanks!
Stock cam
Thanks!
