loose rivet
- Jul 31, 2011
- 151
I became the owner of a rather clean looking 1965 33hp motor today.
(I guess I should also explain that the reason I now own it is that the last owner towed it 25 or so miles with the lower unit dragging the highway).
Thus the purpose of this post.
I've looked high and low for a good lower unit for this but no luck.
What other horse power motors use this same lower unit?
I was told by a local dealer that although the early 25hp lower will physically fit, it won't hold up?
All I've seen so far is 25hp lower units, both off early Johnson 25hp motors and a few early 60's Sea King or Gale 25hp motors.
The upper housing is good, as is the driveshaft, not much else survived. I got lucky and what remained of the lower skeg and screws all came out with little effort. Somehow the driveshaft stayed in place, but the gears, prop shaft, and bearings are gone. The water pump was all that held the driveshaft in place when I got it.
The motor is in super nice shape otherwise and runs perfect.
How far back can I go back or ahead by year to find a lower unit to fit this? What HP motors interchange?
I was told 33-40hp, but it looks like there's a change in the lower unit in the early 70's, at least in the basic casting design if not internally. The later lower unit has a smoother gear case and more angular anti-ventilation plate.
This is a manual shift, short shaft gear case.
Does anyone know what years swap and fit?
Can I convert an earlier 25hp gear case to work?
