If you accidently hooked up battery cables backward inspect the fuseable link. Check all connections on the altenator for proper tightness. Take your voltmeter and set it to AC voltage, put it on the battery posts while the engine is running. If you see more than .25 volts AC you have a bad diode cluster.
