Top of the flywheel are 3 1/4-20 screw holes.Rig up a flywheel puller there.
They sell a lift ring.You need a factory manual,it will tell you what the part # is.J
I remove the crankshaft bolt and put on another that has had a loop of 1/4 rod welded to it ..or put a couple of inches of drilled angle iron under it and a shakle in the vertical arm
