Re: 74 johnson 4 hp
aloha
thank you for the replys and advice it has been sitting few months,i dont have a compression tester but local mech does hes good and nice so ill prob
hire his professional help as i dont want to mess it up and rebuy parts,runs nice when open but when slow she sputters at times i think its the pressure but im
not sure,i bought it from a old timer who had it for a few years and used it often.ill ask the mec to do a comp test and ill probably purchase complete tune up kit
and do the 1-6 like you advised hidef,unfortunately i believe with the use of ethanol(damn corn) it has worn down some rubber as my bubble on fuel line wont
get too hard so maybe a fuel pressure or air issue but fairly small just making it run wonky on low speed,thats some serious cash to throw down to get it right
so ill have to save a little and do it right thanks for the help guys
and as for mixture i went to 40 to 1 last fill up i didnt want to jump to 32 to 1 as chinewalker advised someone else, i wasnt sure if it would flood or foul it up,
i used to ride dirt bikes some and understand 2 strokes a little but am no mechanic my roommate and best friend was so he educated me a little,he was an amazing
mechanic,and passed away in a motorbike accident so i havent rode since and lost touch with tinkering with motors,ill go to 24 to 1 as you advise and see if that helps and check
fuel lines to make sure pressure is good,then ill start the tune up it prob need it done anyways.
lastly anyone have experience with stich and glue boats im planning to build my first 16ft boat from spira int. to learn and maybe step up to a 24-28 ft one day
mahalo
