77glastronssvs188
- Aug 27, 2011
- 2
Ok I had problems with my throttle having to go full to 90 to get any power and it would not go back to neutral I got a new lever arm the dealer said this would fix it.
the part is 34682.
Before I put the control back together I have the cable unhooked should there be tension on the cable if I try and move manually or should it be easy to move. There is quite a bit of tension on the cable to push it back to top dead center. IS this normal?
I am new to this whole thing thanks..
the part is 34682.
