fshrgy99
- Jun 4, 2010
- 69
hello all!
Just installed a 1983 fuel pump and am running premixed gas. One problem to overcome was that the recommended pump did not have a fitting for the vacuum pulse. (This 1989 140 v4 does not appear to have the alternate 'bolt the fuel pump to the auxilliary position' that I have read about.) I fabbed a fuel motor mounting plate to bolt into the old vro mounts and used a brass 3/8 fitting over the central vacuum opening on the pump and then connected the vacuum pulse line to the fitting using an extension on the hose and a 90 elbow.
One glorious day 2 weeks ago I started her on the muffs and low and behold ... a running motor halleluiah!!
Chpt 2
Rented a cottage for the weekend. first it would not stay running. Then I got her running, launched and idled to the dock. First time I took her out I expectantly accelerated but would not pick up beyond a fast idle. Top speed was 8 mph .... (I know she'll do 35-40 at WOT).
Ran like that all weekend. If I leave throttle at WOT she'll overheat but ran for hours if throttle is left at 3/4 or so.
I am thinking either the pulse is insufficient for the fuel pump with the extra line and elbow so fuel delivery is insufficient. Seems like it should run for a short time til bowls are empty? Began wondering about the s.l.o.w. function. I checked the temp sensor wires when I got home and the starboard side was against the #1 spark wire. Read somewhere that might be the problem.
Also have replaced all the fuel line, bulb and filter.
Any comments out there?
Chpt 2
