88 4.3 chevy OMC Cobra outdrive.
Getting hot.
Had outdrive off for several weeks as last owner locked up the upper half solid being low on gear lube.
Installed used outdrive, impeller, fluid, etc. Fired right up with muffs on.
Got hot quickly, exhaust manifolds quite hot. Thought stuck t-stat. Pulled housing and it looks to me that cooling water can bypass a not yet open (or stuck) t-stat and still cool the exhaust manifolds. Right?
Cooling line that comes up to engine from outdrive seems to be blocked. I can't blow air thru it even with the impeller and housing off. Clamped garden hose to top end of fresh-in water hose to try to backflush it. Still blocked.
Read a ton of postings here but couldn't locate this exact issue. Heard mention of power steering cooling, could blockage be there? How do I get to it? Mighty tight down there with v6 vs an inline 4.
Thinking I'll have to remove outdrive again to try to find blockage from that end. It's heavy.
Getting hot.
