I have a 1984 Imperial with a 120 mercruiser with a alpha one lower unit. I have trim pump interment problems. the trim works out of the water, when you put the boat in the water the trim will work at first. Then when you you are running for a while the trim will not go up it will try and go down. in the up position will not even make a electric noise. I have to remove the trim cylinder's to manaully lift the lower unit to get the boat out of the water. Once the boat is off and out of the water of about 30 minutes the trim pump works fine. Any ideas i would greatly appericate it.
