J90PLSIG.
At times it takes 4-6 tries to get it started.
When running WOT, motor does not get above 5100rpms. It has a jet pump.
Before starting, primer bulb does not get hard when squezed. When pinched fuel line before the motor it does get hard.
Suspecting a hole in the fuel pump diaphraghm or a stuck float.
Is there any instruction to pinpoint where the leak is?
Any instruction on rebuilding fuel pump?
Digrahm shows 2 pumps, # 37, and #2. What is the diffirence between those, and which mostlikly might have a problem.
http://www.boats.net/parts/search/B...n shaft/FUEL BRACKET & COMPONENETS/parts.html
thnks.
thnks.
