When I hook my 80 HP outbord motor up to the flush muffs and start the engine, it idles around 1000 - 1200 RPM. As I adjust the RPMs it will get to about 900, but any lower and the engine dies.
My question: If the engine idles at 900 RPM out of the water, will it idle at 900 RPM in the water, or does it drop a certain amount when in the water? What usually is the drop amount of RPM out of the water V.S. in the water?
Thanks.
Thanks.
